[TDF] Announcing LabVIEW Deep Learning module - HAIBAL
Dear Community,
We are proud to announce the next release of LabVIEW Deep Learning module - HAIBAL 😎
The HAIBAL project is structured in the same way as Keras.
The project consists of more than 3000 VIs including, all is coded in LabVIEW native:😱😱😱
  • 16 activations (ELU, Exponential, GELU, HardSigmoid, LeakyReLU, Linear, PReLU, ReLU, SELU, Sigmoid, SoftMax, SoftPlus, SoftSign, Swish, TanH, ThresholdedReLU), nonlinear mathematical function generally placed after each layer having weights.
  • 84 functional layers/layers (Dense, Conv, MaxPool, RNN, Dropout, etc…).
  • 14 loss functions (BinaryCrossentropy, BinaryCrossentropyWithLogits, Crossentropy, CrossentropyWithLogits, Hinge, Huber, KLDivergence, LogCosH, MeanAbsoluteError, MeanAbsolutePercentage, MeanSquare, MeanSquareLog, Poisson, SquaredHinge), function evaluating the prediction in relation to the target.
  • 15 initialization functions (Constant, GlorotNormal, GlorotUniform, HeNormal, HeUniform, Identity, LeCunNormal, LeCunUniform, Ones, Orthogonal, RandomNormal, Random,Uniform, TruncatedNormal, VarianceScaling, Zeros), function initializing the weights.
  • 7 Optimizers (Adagrad, Adam, Inertia, Nadam, Nesterov, RMSProp, SGD), function to update the weights.
 Currently, we are working on the full integration of Keras in compatibility HDF5 file and will start soon same job for PyTorch. (we are able to load model from and will able to save model to in the future – this part is important for us).
Well obviously, Cuda is already working if you use Nvidia board and NI FPGA board will also be – not done yet.
We also working on the full integration on all Xilinx Alveo system for acceleration.
User will be able to do all the models he wants to do; the only limitation will be his hardware. (we will offer the same liberty as Keras or Pytorch) and in the future our company could propose Harware (Linux server with Xilinx Alveo card for exemple --> https://www.xilinx.com/products/boards-and-kits/alveo.html All full compatible Haibal !!!)
About the project communication:
The website will be completely redone, a Youtube channel will be set up with many tutorials and a set of known examples will be offered within the library (Yolo, Mnist, etc.).
For now, we didn’t define release date, but we thought in the next July (it’s not official – we do our best to finish our product but as we are a small passionate team (we are 3 working on it) we do our best to release it soon).
This work is titanic and believe me it makes us happy that you encourage us in it. (it boosts us). In short, we are doing our best to release this library as soon as possible.
Still a little patience …
Youtube Video :
This exemple is a template state machine using HAIBAL library.
It show a signal (here it's Cos) and the neural network during his training has to learn to predict this signal  (here we choose 40 neurones by layers, 5 layers, layer choose is dense).
This template will be proposed as basic example to understood how we initialize, train and use neural network model.  This kind of "visualisation exemple" is inspired from https://playground.tensorflow.org/ help who want to start to learn deep learning.
Youssef Menjour
Certified LabVIEW Architect (CLA)
Technologies de France
Youssef Menjour
Graiphic
www.Graiphic.io
y.menjour@graiphic.io
LabVIEW architect passionate about robotics and deep learning.
Follow us on LinkedIn
linkedin.com/company/graiphic
Follow us on YouTube
youtube.com/@graiphic
Message 1 of 9
(5,876 Views)
That looks very nice!
@YoussefMenjour wrote:
This work is titanic ...
Watch out for icebergs! 😄
Message 2 of 9
(5,850 Views)
nice
Message 3 of 9
(5,794 Views)
I once programmed the inferrence for a CNN - which was train via tensorflow-keras python and exported as hdf5 -  in LabView.
Spoiler
_________________________________________________________________
Layer (type) Output Shape Param #
conv2d (Conv2D) (None, 100, 100, 16) 448
max_pooling2d (MaxPooling2D) (None, 50, 50, 16) 0
conv2d_1 (Conv2D) (None, 50, 50, 32) 4640
max_pooling2d_1 (MaxPooling2 (None, 25, 25, 32) 0
conv2d_2 (Conv2D) (None, 25, 25, 64) 18496
max_pooling2d_2 (MaxPooling2 (None, 12, 12, 64) 0
flatten (Flatten) (None, 9216) 0
dense (Dense) (None, 512) 4719104
dense_1 (Dense) (None, 6) 3078
Total params: 4,745,766
According to your blog post - that is what Haibal is capable to do?
I will definitely look into your Toolkit -
as I haven't tried to interact with NVIDIAs .dlls to speed up the inferrence myself...
Message 4 of 9
(5,752 Views)
Dear Alexder,
The HAIBAL toolbox will propose to the user to make his own architecture / training / prediction natively on LabVIEW.
Of course we will propose natively numerous exemple like Yolo, Minst, VGG ... (that user can directly use and modify it)
As our toolkit is new, we made the choice to be also fully compatible with Keras. This means that if you already have a model trained on Keras, it will be possible to import it on HAIBAL. This will also open our library to thousands of models available on the internet. (all import will traduct on HAIBAL native labVIEW code as editable by users)
In this case, you will have two choices;
1 - use it on labVIEW (predict / train)
2 - Generate all the native architecture equivalent to HAIBAL (as you can see on the video) in order to modify it as you wish.
HAIBAL it's more 3000 VIs, it represente a huge work and we not yet finished. We hope to release the first version this summer (with Cuda) and hope NI-FPGA optimisation to speed up inference. (Open CL and all Xilinx FPGA compatibilities will also come during 2022/2023)
We are building actually our website and our youtube channel.
The teams will propose tutorials (youtube/git hub) and news (website) to give visibilities for users.
Youssef Menjour
Graiphic
www.Graiphic.io
Message 5 of 9
(5,711 Views)
RELEASE DATE
As we have finished the functional part of the library and are starting to work on the optimization part (acceleration of algorithme). We are proud to announce the release date of HAIBAL for the 10 August
https://www.technologies-france.com/2022/05/12/haibal-official-release-date/
Youssef Menjour
Graiphic
www.Graiphic.io
Message 6 of 9
(5,566 Views)
Where do we get the code? I see you mention that it is open source / on github?
Message 7 of 9
(5,457 Views)
Our Sklearn machine learning is free and open source are available here
logo_plaiy
HAIBAL is not Open Source there are 2 engineers working on the project since 10 month. The product will be released soon.
More information available here
Presentation-1-627x376
Youssef Menjour
Graiphic
www.Graiphic.io
Message 8 of 9
(5,449 Views)
Coming soon !
Youssef Menjour
Graiphic
www.Graiphic.io
Message 9 of 9
(5,277 Views)
