TDM Headder Creation
I am trying to create a TDM Header for a single channel binary file. But  when I analyse it with DIAdem I am not getting the waveform correctly.
I am attaching the Binary File Creator as well as the header creator.
(2,667 Views)
TDMS Header creation VIs are available in this link
http://zone.ni.com/devzone/cda/epd/p/id/3399
(2,659 Views)
Hi Cooldude,
I replicated your issue at my end and yes it is not giving correct data.
The problem is with packing of the array.
I have attached a small snippet; make the change accordingly (add build array) and you should be fine!
Cheers!
Ujjval
Message Edited by Ujjval on 12-06-2009 05:54 AM
(2,630 Views)
