TDM write data rate at 2D DBL
Hi!
i try to wite a data aquisition programm. I want to write the data with tdm datastorage. Unfortunately the data rate is not set by picture below. Is there anyone who konws a better way?
Thank you.
Marc
(2,729 Views)
@mawi wrote:
Hi!
Thank you.
Marc
actually I can't understand your question. What do you mean with 'the data rate is not set by picture below'. The sample rate you can set with the timing VI from the daqmx palette.
(2,710 Views)
Hi Michael,
the datarate is not set in the tdm file.
Mikro11
7,5 m, 1,2 m Höhe
#xpointer(id("usi2"))
V
DT_DOUBLE
-0.0701141357421875
0.0703887939453125
Time
s
430080
1
it hast to be 5.55e-5 and not 1.
0
2005-04-05T11:48:42.95099973678588867
relative
#xpointer(id("usi10"))
i think it is a bug.
My solution was to write the datarate in a user def part and read it from there. it is not the best way.
No transfer to diadem ist possible with this.
Marc
(2,706 Views)
@mawi wrote:
Hi Michael,
Mikro11
7,5 m, 1,2 m Höhe
V
DT_DOUBLE
-0.0701141357421875
0.0703887939453125
Time
s
430080
1
0
relative
Marc
Hi Marc,
look the attached screenshot. You have to change the data type to waveforms than you get the timestamp.
Message Edited by MichaelP on 04-08-2005 04:45 AM
(2,700 Views)
Hi Michael,
that i try also, but the tdm makes one channal in to parts and forgott the Name. So i find this solution.
If there is an another posibility to avoid this o.k.
Marc
(2,692 Views)
