TDMS File FormatW
We are looking into the new TDMS file format. One problem we've got is that the file structure is bad(not) documented. If  I create a file with a 'untitled' group and 'untitled' channel and a U8 data set from 0 to 99 I get the followin files
.tdms:
.tdms_index:
I can't find anywhere my data so it is propably compressed, does anyone (NI?) know the file format or is a white paper coming?
Ton
Message Edited by TonP on 09-15-2006 11:18 AM
My LabVIEW Ideas
(4,382 Views)
Ton,
Just did a search on the website and found these
I would guess you have already seen them and hasn't helped you.
Trying to help ...
David
(4,372 Views)
Yup have seen them, but I am looking for documentation on how the data is stored so that we can write a note on it, and we can read the files in 10 years or so with any software.
I like the TDMS format because it allows me to store a lot of info about the data (sensor/daq/computer) in an easy way. And it is compressed just this week I had a measurement of 9 channels 20kHz for 10 minutes (500 MEG in txt) and the binary file was much smaller but needed a conversion tool for a third party so ge sticked with the txt files....Smiley Mad
Ton
My LabVIEW Ideas
(4,369 Views)
Take a look at the bottom of this page
https://www.ni.com/en/support/documentation/supplemental/06/the-ni-tdms-file-format.html
Maybe the contact listed might be able to help?
David
(4,368 Views)
OK,
one error I made this data is uncompressed available (look at the top picture starting at byte x98.....
And I thougth the alphabet was some kind of mapping mechanism...
Then I tested it with an array of DBL's of 10Meg elements, yes the file was 80.000.150 bytes sized apparently if there is one channel the tdms_index file is at the top of the TDMS file
Ton
My LabVIEW Ideas
(4,358 Views)
