TDMS File Viewer
What can i do if i accidentally deleted the TDMS File Viewer.vi?
(2,763 Views)
You could copy the VI from another system.  The option would be to do a re-install/repair of LabVIEW.
(2,740 Views)
Accepted by topic author skata200
I was fairly pleased recently with the repair functionality in recent LabVIEW (via NI Package Manager).
You can repair specifically vi.lib by going to the "Installed" tab and then searching for "VI Library". Note that if "Products only" is ticked (and I think this is the default) you won't find it - so uncheck that box.
(2,688 Views)
