TDMS File has too many samples
Hello!
I am attempting to generate a new TDMS file per trial and each file will contain the information for 10 seconds of each trial. Even though I have set the sample rate as 1 sample per 0.001 seconds and am collecting data for 10 seconds, the TDMS file has more than 10,000 samples. When I examined the TDMS file I see that some data points are saved twice (as in one time stamp is repeated 3 to 4 times). I am unsure of how to make sure only 10,000 samples are saved to the TDMS file. I have attached my VI and would appreciate any help!
(1,328 Views)
Check the Iteration terminal at the bottom left of the while loop to see how many iterations have actually run.
Using variables to stream data across loops is a terrible idea.
You should use Producer/Consumer Read Waveform Data and Write to TDMS
Or you could use the built-in logging feature of NI-DAQmx. See NI-DAQmx High-Speed Streaming to Disk
https://tmesystems.net/
(1,318 Views)
