TDMS Icon and clusters... why not?
I want to use TDMS file, but I can't link wire from cluster to TDMS icon. See this figure to understand:
I can use array, I can Use Merge Signal, but no cluster... also if cluster is a cluster of numbers. Why?
What is the excellent way to use TDMS Icon? What type of wire are better to use?
It's possible to "unbundle" also an array. Can u show me how?
(3,374 Views)
Hi Michelle1892773,
Cluster is not supported for TDMS Write now, you'd better write an array to a TDMS channel.
(3,352 Views)
is there any specific reason for are using "cluster"? because you are unnecessary complicating the data type.
If there are no issues then go for arrays
Regards
Guru (CLA)
(3,340 Views)
If you want to use a cluster to store settings as properties for a file/group/channel, you can use the following code (here I store an error cluster):
It uses code from OpenG toolkit.
Ton
My LabVIEW Ideas
(3,322 Views)
