TDMS Opens Slowly
My understanding is when you open a tdms file it verifies the index, or recreates it if it's missing. So the more fragmented the file the bigger the index and the more slow IO needed to verify/recreate it.
Message 11 of 12
(389 Views)
I can explain.
When you call TDMS Open in LabVIEW, TDMS needs to load all the meta data information in tdms_index file, instead of just opening a file reference like txt or binary file does. So, as you mentioned, the more you deframent the file, the smaller the index file is, the quicker TDMS Open will be.
Message 12 of 12
(382 Views)
