TDMS Timestamp Decoding - Help!!
Hi Brad,
Thanks very much for providing the program. Could you suggest how to resolve the following error please?
??? Invalid field name: '33P11Voltage1'.
Error in ==> convertTDMS at 121
                    ob.(obname)=[];
Best,
Wilroy
Message 31 of 42
(4,847 Views)
The code uses the channel names for the variable names in MATLAB.  Variables must begin with a text charateric (not numeric) in MATLAB.  That looks to be the problem.  I will see if I can come up with a fix for checking the variable name.
Message 32 of 42
(4,816 Views)
First thanks for your code,actually I tried to use this code for converting a tdms file,but I got this error:
Error using fread
Invalid precision.
Error in convertTDMS (line 174)
propsValue=fread(fid,1,matType);
is there any possibility to solve it?!
Message 33 of 42
(4,343 Views)
Hi Navid777,
Have you tried changing the matType to other datatypes? The error message:
Invalid precision.
indicates that whatever "matType" is doesn't work with the function fread.
Aldo A
Message 34 of 42
(4,315 Views)
Hi Aldo,
firstly thanks for your answer.
I did not change anything,as a beginner I just guess maybe it's because of the way that data has been stored in my TDMS files,when I open the files there is no channel and group,it's kind of DAQ. Actually I have tried to understand the difference between these two but was not successful!
Could this error happen because of that?
Navid
Message 35 of 42
(4,297 Views)
Hi Navid,
From reading this thread, it seems that other people had similar issues with that function too and the cause mostly pointed to fread being unable to read in the timestamp properly.
If you take a look at page 2 of this thread http://forums.ni.com/t5/LabVIEW/TDMS-Timestamp-Decoding-Help/td-p/691745/page/2 the author of the script addressed the issue.
My recommendation is to study messages 14-17 so you can get a better understanding of the input files the script will work with.
Aldo A
Message 36 of 42
(4,275 Views)
The first 4 bytes are type code. After that each timestamp value is represented by 16 bytes. The first 8 bytes is the milliseconds, and the other 8 bytes is the number of secs since 12:00 a.m., Friday, January 1, 1904 (0:00:00.000 1904/1/1). Notice that all these bytes are represented in little-endian.
Message 37 of 42
(4,255 Views)
Navid,
It looks like you may be OK with the timestamp issue but I saw that you still had other problems on the Mathworks site.  Are you still having problems?  If you can upload a small data file here, I might be able to trouble shoot your issue and update the function.
By chance, are you using tdms version 2.0 (check your tdms write block)?  If so, I don't think it is supported yet.
Brad
Message 38 of 42
(4,248 Views)
Hi Brad,
Thanks for your answer.
Actually I don't need anymore to change the format like that,because I was goanna to manipulate some data in tdms file and I found out it's possible to do this stuff in DIAdem.
In DIAdem we can save  tdms file as a math file,but the point is, that file would be really large so I need to at first do "down sampling" and then save the new file as math file in order to use it in Matlab.
Best,
Navid
Message 39 of 42
(4,227 Views)
Just a suggestion for those with big files (GB).  In my TDMS write subvi's, I build in a capability that peridically (based on elapsed time or file size), stops the file and opens a new one.  A timestamp is appened to the end of the file name.  This is good practice in general just to mitigate file corruption issues.  It also allows you to batch post process files in chuncks.
Message 40 of 42
(4,219 Views)
