TDMS and null strin char
Why is it not possible to write a string that contains null characters (\00) in a TDMS property?
(this limitation is documented in the help)
I've just spent half a day to spot the issue and now I found a work around, but I'd like to know why such a limitation 😮
Anyone knows?
Edit :
Side question, if you do try to write a property string that contains a null strin char, should you receive an error, or a warning, or nothing?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,478 Views)
Accepted by topic author TiTou
the null character (\00) is a standard way of marking the end of a string. If you put a null character in the middle of a string, many programs will consider the string finished as soon as the character is reached and ignore the rest of the string.
Because of this behaviour, it isn't an error and so shouldn't throw any errors if you try to do it.
Joseph Tagg
(4,451 Views)
Right, that answers my question.
Thanks Joseph!
I'll start a new thread to discuss more general issues I have with TDMS properties.
Epictetus
Antoine Chalons
(4,433 Views)
