TDMS file time conversion for matlab
I'm using LabView 2015. I have recorded a TDMS file (attached) from myRIO project (columns representing: time stamp, time* and several signals). As you can see in the first column (that I call time stamp) milliseconds are not evenly distributed and the second column (time*) is giving a number of sample. I need to be able to plot these signals depending on the time (x-axis), each sample as it occurred in time (even if it means millisecond resolution in x-axis). Lay terms: I need to plot my signals depending on time in either Labview or Matlab please.
Could you please be able to help me? Thanks.
Message 1 of 1
(2,653 Views)
