TDMS get Properties problem...
I am working in Labview 2009 and DIADEM 11.1
I created a VI that write propertie in a TDMS file but with a property name with a space in the name.
I created a VI that read the same propertie. It is working find (With space in labview.tdms)
If I open the tdms file in DIADEM and modify the value property and save the file. (With space in diadem.tdms)
When I use the same read propertie, there is no error message but the found boolen value dont find the properti.
Thanks!
I can not joint the TDMS file
(2,792 Views)
Hi cynt,
Your question has been answered on this forum.
Ryan T
(2,774 Views)
