TDMS - get properties
Hi, I have TDMS file and I want to read the properties but I can do it only for the first file content 00_003_2_HL_ ... as it is shown at the picture. However I want to get the other properties such as Fs, unit_string, ...
I believe it is possible but I cannot find the solution. Please help. The best way is with some example.
(3,121 Views)
Accepted by topic author charlie87
Hi, I'm not very clear of what your real problem is.  On which objects do you want to get the other properties? group? channel? More information is appreciated, if you are not familiar with TDMS file formats, you can refer https://www.ni.com/en/support/documentation/supplemental/07/tdms-file-format-internal-structure.html
(3,105 Views)
Ohh. It was exactly what I was looking for....
(3,097 Views)
