TDMS read "loses" data when used in multiple instances
My original code used a for loop. I tried creating a simplified for loop without the post-processing at the start of my troubleshooting and then went to the individual reads as in the VI in the image above. I will attach the original executable for perspective.
I need to open and process three to five files. The issue I am seeing only occurs in the second and third read.
I will try to attach a data file but I suspect it will not work. The data files causing the issues are approximately 25 mb in size. I can run the same sequence on files I have generated that are around 1.8 mb without issue, but unfortunately I do not see a way I might be able to cut down the size of the data files, as I need to observe transient effects in between loading applications.
Message Edited by JohnnyF on 11-04-2009 07:21 AM
Message 11 of 13
(811 Views)
You can have a faster way to determine the number of for-loops to run:
Maybe your problem lies in the missing initialization of the shift register in the upper minor for loop:
Ton
Message Edited by TCPlomp on 04-11-2009 03:02 PM
My LabVIEW Ideas
Message 12 of 13
(806 Views)
Thanks for the advice-always nice to find a way to increase speed.
Regarding the uninitialized for loop you pointed to, that does not seem to affect the results as I see the same erroneous data when I run my simplified code like this one:
Message 13 of 13
(798 Views)
