TDMS refnums, not a refnum compare and feedback node
Hey guys,
I have an issue with the refnum to an TDMS file. I've written a VI which generates a TDMS file, if it is not existing yet and is storing some data inside. Since this VI will be continuously recalled, I dont want to close the TDMS file, but pass the reference to the next call of the VI. To do so, I pass the reference to a feedback node.
When I first run the VI, the left refnum compare returns true and the right one false as expected (cf. probe watch).
However, if I run the VI again the feedback node seems to return the correct refnum (compare probe watch) but both the not a refnum compare functions return true! This behaviour is confusing me.
Maybe there is some misconception on my side. Can someone explain to me, whats going wrong here?
Thanks & Cheers,
Jens
PS: find the MWE attached
PPS: Edited due some text loss when posting
(1,553 Views)
Accepted by topic author Dr.Polz.Photonics
Hi Polz,
when the VI stops execution LabVIEW will automatically close all references for you.
So even when the feedback node gives a reference in the next run that reference is not valid anymore!
You can prevent the automatic reference cleanup (kind of garbage collection) when your VI is called in a context where the execution is not stopped, like when you call the VI as subVI in a loop of your mainVI…
(1,522 Views)
Hey GerdW,
I am embaressed. Could have thought of that one myself...
The VI is going to be a subVI anyways, so no trouble at all. Just wanted to test it before deploying it to the main program. Thanks for the eye opener.
Cheers,
Jens
(1,515 Views)
