TDMS to XLSX in Excel
I want to import tdms file and convert them into xlsx files. I will have many files to convert so I want to do batch processing.
I've installed the add-in, and written two VBA macros.
The first one works, but needed the user to convert file by file (with the GUI).
The second one works partially because the file is opened, but not converted...
Can someone explain me the difference between my two macros, and why the second macro doesn't convert the file ?
Thank you
Macro 1 :
Sub TDMImport()
'Get TDM Excel Add-In
Dim obj As COMAddIn
Set obj = Application.COMAddIns.Item("ExcelTDM.TDMAddin")
obj.Connect = True
'Confirm only importing "Description" properties for Root
Call obj.Object.Config.RootProperties.DeselectAll
Call obj.Object.Config.RootProperties.Select("Description")
'Show the group count as property
Call obj.Object.Config.RootProperties.Select("Groups")
'Select all the available properties for Group
Call obj.Object.Config.GroupProperties.SelectAll
'Import custom properties
obj.Object.Config.RootProperties.SelectCustomProperties = True
obj.Object.Config.GroupProperties.SelectCustomProperties = True
obj.Object.Config.ChannelProperties.SelectCustomProperties = True
'Let the user choose which file to import
Dim fileName
fileName = Application.GetOpenFilename("TDM & TDMS (*.tdm;*.tdms),*.tdm;*.tdms")
If fileName = False Then
 'User selected Cancel
Exit Sub
End If
'Import the selected file
Call obj.Object.ImportFile(fileName)
'Workbooks.Open (fileName)
'Record down the current workbook
Dim Workbook As Object
Set Workbook = ActiveWorkbook
        Workbook.SaveAs ("C:\Documents and Settings\bzm924\My Documents\post traitement\moyenne courant de commande\04_Traces\400bar\1.xlsx")
        Workbook.Close
End Sub
Macro 2 :
Sub TDMImport(fileName As String)
Dim obj As COMAddIn
obj.Connect = True
'Dim fileName
'fileName = Application.GetOpenFilename(Dir)
'If fileName = False Then
' User selected Cancel
'Exit Sub
'End If
'Call obj.Object.ImportFile(fileName)
        Workbook.Close
End Sub
Message 1 of 9
(6,531 Views)
Haven't tried it out, but could it be that
needs to be
instead?
Message 2 of 9
(6,508 Views)
In fact, the two macros are identical. I've just comment or uncomment certain parts.
If I put :
In macro 1, it's Ok. But if I do it in the second one, I've got a runtime error number 5. That's why I've tried to put :
With a Woorkbooks.open, i'm able to open the file, but not to convert it, that's my problem.
Message 3 of 9
(6,504 Views)
I know you specifically said "in Excel" but you are in the LabVIEW forum so here is the LabVIEW solution:
http://forums.ni.com/t5/LabVIEW/Convert-Import-TDMS-to-Excel/td-p/1088746
You could build it into an EXE and then you'd be set.  Optionally you could look at the LabVIEW source and you may get an understanding of what you need to do, to import it properly.
Message 4 of 9
(6,493 Views)
You can find attached a working solution to my problem.
Sub ImportTDM()
Call GetTDM("c:\Voltage.tdms")  '### path to be adapted ###
End Sub
Sub GetTDM(path As String)
Dim ComTDM As Object  'COMAddIn
Dim TDM As Object     'ExcelTDMLib.TDMAddin
Set ComTDM = Application.COMAddIns.Item("ExcelTDM.TDMAddin")
ComTDM.Connect = True
Set TDM = ComTDM.Object
Application.ScreenUpdating = False
TDM.ImportFile fileName:="" & path & ""
Application.ScreenUpdating = True
End Sub
The Whole discussion can be found here (in french !)
Bye
Message 5 of 9
(6,460 Views)
Hey Bro,
I m new to VBA excel and I m working on tool to prepare report based on .xlsx input. Basic need for it is converting bunch of .tdms files to .xlsx .
Can you suggest me a solution to convert bunch .tdms files at location 1 to corresponding  .xlsx files at location 2.
Kindly revert back in case of any further concerns.
Message 6 of 9
(6,281 Views)
@jadhavpp2 wrote:
Hey Bro,
Once again I will link to a VI that converts from TDMS to XLSX, next time please read the entire topic.
http://forums.ni.com/t5/LabVIEW/Convert-Import-TDMS-to-Excel/m-p/1089923#M482267
Message 7 of 9
(6,272 Views)
Hey hooovahh
Thanks bro... But I need help in VBA excel code ...not LabVIEW...
Message 8 of 9
(6,260 Views)
@jadhavpp2 wrote:
Hey hooovahh
Yeah sorry about that.  But you can look at the LabVIEW code and see how it does it and then do the same code in the VBA.  I do the reverse all the time because they both essentially just use ActiveX to get the meat of the work done.
Message 9 of 9
(6,243 Views)
