TDMS write does not accept data ???
HI
I am using PXie 4330 and I would like to save my data , I am calibrating the pexie and I just want to save data automatically but first problem is I can't connect output data, to write TDMS ? what can I do ?
(2,627 Views)
The first thing you can do is show us your code  Smiley Indifferent
From the TDMS Write Function help file:
The data input accepts the following data types
  • Analog waveform or a 1D array of analog waveforms
  • Digital waveform
  • Digital table
  • Dynamic data
  • 1D or 2D array of:
    • Signed or unsigned integers
    • Floating-point numbers
    • Timestamps
    • Booleans
    • Alphanumeric strings that do not contain null characters
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,613 Views)
