TDS 2014 oscilloscope does not connect via GPIB (LabVIEW 8.6.1)
I have a TDS 2014 oscilloscope and |I would like to connect from LabVIEW 8.6.1 to this oscilloscope via GPIB
interface (CEC PCI 488 card) . Simple GPIB blocks (Instrument I/O -> GPIB) work
but VISA blocks don't . Measurement &  Automation Explorer does not find the oscilloscope.
I have upgraded VISA and GPIB, but this did not help
Simple vi that uses only WRITE and READ VISA blocks and sends a message *idn?
return error:
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
I would be grateful for any help.
(3,149 Views)
MAX is for NI cards. You would need a VISA driver from CEC and enable tulip support in MAX.
(3,146 Views)
Hi Katarzyna,
Please try to use the function called "VISA Find Resource" (Instrument I/O->VISA->Advanced) which search for the VISA resources on GPIB. Please find help for that function http://zone.ni.com/reference/en-XX/help/371361E-01/lvinstio/visa_find_resource/
Example usage You may find below:
Moreover, instead of programming communication from the scratch You can use instrument drivers. Please find the link to it: http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=540
If there will be any questions please let me know.
Wojciech Sommer
(3,096 Views)
thank you for your help. It turned out that installing the most recent CEC driver alone did not help.
I had to install the most recent VISA as well.
Many thanks,
Katarzyna
(2,971 Views)
