TDS 3032B Oscilloscope Ethernet
I'm trying to get Labview to recognize my TDS 3032B oscilloscope in the "Create New Visa TCP\IP Resource". I have the correct IP address and I set the name of the instrument to AA11 but labview still won't recognize it. I've tried it without the instrument name and it still will not work.
   It list the VISA string as TCPIP0::10.0.24.37::INSTR . The error code is 0xBFFF0011. Any help would be appreciated.
(3,138 Views)
What version of LabVIEW and VISA are you using?
Has it been able to be recognized in MAX if you creae the TCP/IP resource there?
Jeff | LabVIEW Software Engineer
(3,122 Views)
