TDS oscilloscope
Sorry mathan
In the modified program, when i press the start button it is analysing the singal,then when pressing the stop button it displays the value,also i need to stop the complete program.
The scope gets the continuos signal,is it possible to stop the waveform in the scope when i press the start button.
Message 11 of 16
(1,079 Views)
Hai vrk,
am sorry. I can't able to exactly get u. Could u please explain bit more detail about ur requirement.
Mathan
Message 12 of 16
(1,075 Views)
Basically the the scope gets the continuos signal from measurement,the program measures the value of the signal(at the moment just peak to peak).Thats working fine.
But i like to do it bit more advanced. Now when I press the Run VI button the program starts,then i am pressing the start button to analyse the signals value and again the same button to stop it. After that the whole program is stopping it keeps going.I will do this bit later.
This is more important,Now when i press the start/stop button at first instance for example the green light should turn on indicating its measuring the value,when i press it again another light some diff colour should turn on indicating the measurement is finished,also the LabVIEW program should stop.
Message 13 of 16
(1,071 Views)
Hai vrk,
Based on my understanding of ur subject, i have attached vi here. kindly post if further modification required. Thanks.
Mathan
Message 14 of 16
(1,029 Views)
Thanks Mathan
Thats a perfect solution,excellent.
Once again thanks
Message 15 of 16
(1,023 Views)
Hai vrk,
Nice to hear that, that worked.
I think you are fighting with this vi for more than 2 days. Am happy to solve this for you.
Mathan
Message 16 of 16
(1,020 Views)
