TDS640 PIB Hardcopy"Clipped"
I'm using GPIB to save the hardcopy image to a computer. The read/write is simple enough. Send the hardcopy command:
HARDCOPY PORT GPI; HARDCOPY START
Then I'm using a VISA Read to save the image to a text file. The issue I'm having is that my images are "cut" half way down. Any ideas?123.jpg
(2,852 Views)
Hi
Did you try increasing the byte count for the VISA Read function to see if made a difference?
Regards
Arham H
(2,820 Views)
I'm already using 100k, even though my captures are only about 45k. I will try it though, see if it makes a difference.
(2,809 Views)
You might also need to increase your VISA timeout.  Are you getting any errors or warnings?
(2,803 Views)
With my VISA time-out increased to 5000ms, it's still occurring. Could this be related to how I'm saving off the file? I'm reading the data to a text file, then saving it to a .BMP on the local machine. However, an image would be binary, right?
(2,771 Views)
Ok.  I see a couple of problems there.
1.  Do the hardcopy as a PNG.  It is a much smaller file than the BMP and will still look good.  Less data over the bus is almost always better.
2.  Use the VISA Read to File function.  It is a single function that will read that data from the bus and save it direcly to a file.  Your other alternative is to right-click on your Write to Text File and uncheck "Convert EOL".  It is likely the convertion of the EOL that is messing up your image.
(2,762 Views)
