TDS7704B Timeout Trigger
Hi
I am using TDS7704B Oscilloscope. I need to use TimeOut Trigger in Advance Trigger function. I do have drivers for this instrument, i am able to set all the trigger paramaters, but not able to understand, how to detect if the trigger has occured or not. Physically i am able to see that trigger is happening under required conditions !!...
I could not see any VI's to detect if trigger has occured or not ?????  Smiley Sad
Thanks & Regards,
Rajan
(2,893 Views)
Ok.. i'v found ... there is a "trigger query" command avaialble in the manual ..
Thanks for reading the post.. lolz Smiley Very HappySmiley Very Happy
Thanks & Regards,
Rajan
(2,882 Views)
