TFS Source Safe Question?
Hi all,
I am going to be using Visual Source Safe TFS for my LabVIEW code. Bascially, I will check in all my code into one folder that is C:\TFS. I have the following questions.
For drivers, library, personal personal perference in LabVIEW, they are scattered in different places in c drive (program files, my documents, etc). How do I check them in to my source safe, since everything must be under C:\TFS?
Yik
Kudos and Accepted as Solution are welcome!
(2,866 Views)
Go to Tools>>Options>>Paths then open the pull-down menu you will see default directory and search paths. Hope this helps.
(2,861 Views)
