TI DSP Toolkit with Code Composer Platinum
I've been using the LV DSP toolkit for TI with Code Composer 2.2x for some time with no problems.  Recently upgraded to CCS Platinum and the DSP VIs aren't behaving as they used to.  Primary problem is trying to open CCS, looks like it tries to open then immediately closes back down.
Has anyone else used the DSP toolkit with CCS Platinum?  I may just switch back to CCS 2.2x.
Best regards and thanks,
Matthew
Message 1 of 1
(2,589 Views)
