TIFF Saving in Labview using open-source libraries
My image(s) is 12-bit grayscale utilizing the U16 format ... The buffer array is a 4-byte array (32-bit) array... I am currently looking to see if I can customize any of the suggested ideas here since I remember reading somewhere that TIFF saving is usually done as a byte-array (in most of the libraries available / developed , LabVIEW or otherwise) .... Also I would be doing both reading and writing of the images and I want them to be displayed as per their true pixel values (Even using a byte array I can code 4-byte data consecutively for each pixel , but I am guessing that could cause a display issue when I open my images) ... Lot of options to play around with ... Let me get back on this...
Message 11 of 12
(903 Views)
@RTSLVU , Saving as TIFF is a part of a small process built on LabVIEW ... Its not exactly a standalone requirement ...which is why I want to incorporate TIFF saving in LabVIEW with the rest of the process...
Message 12 of 12
(902 Views)
