TLS And TCP/IP
I must use TCP/IP and TLS in a project but i can't find any help or solution how to do it.
Does any one know how to do it?
(4,102 Views)
I am not so much clear about TLS(transfer layer Security) over TCP/IP, but you can secure your data using some techniques.
1. You can use flattern to string function to transfer you data over TCP/IP. This is a secure method to transfer your data over TCP/IP.
2. You can use encryption to protect your data over TCP/IP.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(4,097 Views)
LabVIEW has no native support for TLS/SSL.
For those who need/desire such functionality, please support this Idea Exchange entry:
Native SSH and SFTP Support
(4,085 Views)
I think I use functionality implemented in .net to solve the problem.
(4,068 Views)
