TLS with Client Certificate
How can I add a client certificate to a TLS connection? I am using LabVIEW 2020 and I am connecting to a server that requires a client certificate. I am not seeing how to add the client certificate. For HTTPS and SMTP there is a configure TLS vi which includes an input for the client certificate however I do not see that in the base level TLS VIs.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,046 Views)
I haven’t used them yet but aren’t these functions what you need?
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/data-communication/protoc...
Rolf Kalbermatter  My Blog
(2,023 Views)
Yes, those are the VIs we are using however I don't see any way to specify the client certificate. I can add a CA certificate. I can add a private key but I cannot define the client certificate. If you look at the network trace the client hello packet includes a section for the client certificate but it is always empty.
Mark Yedinak
LabVIEW Champion
(2,013 Views)
Then I have to defer this to someone else, hopefully someone from the LabVIEW team will see this. It very well might have simply been forgotten.
If a third party Toolkit would be an option you might want to take a look at the LabVIEW Encryption Compendium. It’s a fairly extensive library supporting IPv6 and TLS among more specific pure encryption functions.
(1,993 Views)
Hi Mark,
I am facing the same problem, have you found any solution for this ?
(1,771 Views)
