TPC 2106T :cannot access serial port
I used visa read function to read the serial port through Tpc but the bytes is always zero.
HOw to access the serial port?
kavi
Message 1 of 12
(6,130 Views)
You should be able to do Serial communication on the TPC-2106/T using the Serial Compatibility VI's. You can find these VI's by accessing the Functions palette on the block diagram and navigating to Instrument I/O»Serial Compatibility.
I hope this helps.
Message 2 of 12
(6,126 Views)
I used the same serial compatability vis to read again the same problem persists
kavi
Message 3 of 12
(6,120 Views)
From what I understand, you are trying to send serial data to the TPC-2106/T, and it is not reading the data, and it just returns 0 bytes read. Is this correct?
What are you using to send the serial data to the TPC, and can you confirm its doing this?
Message 4 of 12
(6,115 Views)
Can you post a screen shot of your vi?
Message 5 of 12
(6,110 Views)
Im using a Barcode scanner.
kavi
Message 6 of 12
(6,095 Views)
any solution?
kavi
Message 7 of 12
(6,089 Views)
The scanner is sending data i checked by connecting the scanner to my pc
kavi
Message 8 of 12
(6,088 Views)
You haven't specified any of the initialisation values:
Are you sure the default values are correct? (for example, 9600 baud, 8 bits)
Could you post a link to the datasheet of the scanner?
Thanks!
Message Edited by macaba on 07-28-2009 06:43 AM
Message 9 of 12
(6,076 Views)
Even i tried writing data to TPC through My Pc using visa write .Again the same problem i faced.I think its not a fault on Scanner data.
kavi
Message 10 of 12
(6,068 Views)
