TPC-2206 portrait mode
I have a TPC-2206 with Win7E, and I want to switch it to portrait mode.  I download a front panel that I had set up to look like portrait mode, but it didn't work.  I looked through the touch panel's control panel settings and couldn't find a solution.  I also looked for a way to set the mode in LabVIEW and didn't find a setting there either.  Any suggestions?  Thanks
(5,916 Views)
I dunno about TPC, but on traditionnal desktop you can do this through your graphical card options.
On some cards, if the hot keys are enable, doing CTR+ALT+Up/down arrow will rotate your screen dispay.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(5,913 Views)
I Googles "window 7 screen orientation" (and about a thousand other items).  One hit said that there should be a selection under ControlPanel/display/resolution for orientations.  They had pictures so I know i was in the right spot, but Win7 Embedded did not have that option.
(5,904 Views)
I suspected it was a driver problem since the TPC-2206 only came with a generic windows driver.  When I tried to open the Control Panel>Adjust Screen Resolution>Advanced Settings>Adapter tab I got an error message that said “Error Detected: Aborting.  Please verify if EMGD is active.”  After confirming the error I could open the tab but it was unpopulated.  When I first got the error message I Googled for EMGD but didn’t get any helpful information.  This time I Googled the whole error message and found this link:
http://www.intel.com/content/www/us/en/intelligent-systems/intel-embedded-media-and-graphics-driver/...
I downloaded the driver for the Intel Atom Processor Z5XX Series and installed it on the TPC-2206.  From the windows Start mentu, go to Control Panel>Adjust Screen Resolution>Advanced Settings>Adapter tab.  Then click on the Adapter Type Properties button and a properties screen pops up.  Click on the Driver tab and the Update Driver button.  Click on Browse My Computer for driver and navigate the C: drive to find the new Intel Driver folder.  Once Ifound the folder, I clicked on Let Me Pick from a list and selected the driver.  The system will want to reboot.
Now I went back to the Control Panel>Adjust Screen Resolution>Advanced Settings screen and clicked on the Display Config tab and all of the options fields were populated.  Towards the bottom is a Rotate option.  Click on the down arrow and rotate the screen 90 degrees (or 180, 270).
(5,833 Views)
Thank you Rick.
Your instructions were perfect.
Succesfully managed to get portrait mode in my TPC 2206.
Jag
(5,470 Views)
