TROUBLE READING OMEGA TRANDUCER PX409-015CGI
Hello everyone,
I'm having trouble to read this pressure transducer in labview. NI 9232 is connected with the pressure transducer by using crio9074
Really need help to solve this
Message 1 of 9
(3,329 Views)
Hi qila,
Which trouble(s) do you have?
How can we help when all we get is an image of your hardware on a bench?
Message 2 of 9
(3,324 Views)
refer to the attachment below for the vi.
Message 3 of 9
(3,319 Views)
Hi qila,
unfortunately you didn't attach the project file.
(And also unfortunately I'm stuck at LV2017, so it would be fine to downconvert before attaching the whole project!)
Message 4 of 9
(3,307 Views)
lv17 version
Message 5 of 9
(3,246 Views)
Please explain the connection between the sensor and module. What type of output does the sensor have, and what type of input did you connect it to?
Message 6 of 9
(3,219 Views)
connection ( pls refer to the image below)
output: mA
input: measure air pressure of a normal room
Message 7 of 9
(3,189 Views)
Hi qila,
hwo do you supply that sensor?
Did you read the datasheet of your sensor? It needs "9…30Vdc power supply"…
Message 8 of 9
(3,181 Views)
I meant, what kind of electrical input did you connect the mA output of the sensor to? What I was getting at was that your sensor has a 4-20 mA output so it needs to be connected to a mA input, not the voltage input on the NI-9232, and it also needs a power supply like GerdW mentioned.
Message 9 of 9
(3,169 Views)
