TS UI Sequence View Control Properties
Hello
Im working with TS 3.1 LabView Operator Intterface, Im using LV 7.1. I am trying to get data from the Station Gobals to present this info in the Sequence View Control. The issue I am dealing with is that when I type an expression for evaluating a given field in a column the whole column is evaluated at once thus all the column is filled with the same data, what I woukld like to do is the column to be evaluated every time a step is run, i.e. line per line. The perfect solution for this issue is to get the index of the current line and take it as a condition for evaluating the whole column, is it possible to get the information of an INDEX COLUMN to evaluate this info in an EXPRESSION COLUMN?
Thanx in advance
(2,810 Views)
Yes it is possible to get the information from an Index Column in an Expression Column inside of the SequenceView Control. You can do this by typing RunState.StepIndex into the Expression Column that you created. I hope that this information helps you out.
Kevin L.
(2,787 Views)
