TTI CPX 400DP CC MODE CONTROL
i have tti 400dp power supply and i control it with labview. when i look at the labview driver, they only present cv mode labview programs which i only control voltage output. But i need to apply constant current sources so i need to use cc mode of the device. there is also no command in the manual about to cc mode but i manually use cc mode with constant current output at the device. the labview library of cp400 is little bit different since the commands were related by a dll file. so does anybody know to control cc mode and apply constant current at cpx400 by labview
Message 1 of 1
(2,075 Views)
