TTI PL 303 QMD-P
HI ,
I want to know how to download and install the TTI PL303 QMD-P LabVIEW Driver in order to use it ?
Thank you .
(3,447 Views)
Hi Emna,
just do what the IDNet website says:
Note the items in the last paragraph…
(From reading the specsheet it should be simple to remotely control this device using a (virtual) COM port! Reading the manufacturer website even more carefully you would notice their offer of a "combined LabVIEW and LabWindows driver". And you could read the manual also offered on that website to learn about all the remote communication details!)
(3,426 Views)
Hi ,
Thank you ;
i need information about how to use this driver ?
When i installed the driver the programme  ask for this file " ivi.dll " i needd explanation for this ?
(3,405 Views)
Hi Emna,
how do you connect with this device? Are you using RS232, USB/VCP, GPIB or LAN?
It might be easy to create your own driver using any of those communication ports…
(3,393 Views)
Hi GerdW
i  using Ethenet to connect with PL 303 QMD- P
Thank you.
(3,333 Views)
