Use TTL. It is likely that the TCP/IP messages will get there fast enough
and that the software will respond in a timely manner but there is no way to
be sure. It is the fastest way to get from your LV application to your
other device. You may need to check the response time that the BioPac will
give to the TTL input verses a TCP/IP message.
You should also consider the level of programming needed to accomplish your
tasks. I would strongly suggest that you get a seasoned LV programmer on
the job or you will be wasting a lot of time and enduring needless
frustration.
The parallel port will respond is sub-millisecond. You should be able to
toggle it several hundred times in a millisecond. I've had LV applications
use the printer port for this type of communications before. I don't
remember the bandwidth but it's more than adequate for this application.
TCP/IP will sometimes get delayed by the OS (either Windows or Linux) due to
other things that are happening at the time which you don't have control of.
The message should go out in very short order (again sub-millisecond) but
there is no control over this.
Good luck,
Chuck
"Donat-Pierre" wrote in message
news:506500000008000000F2FF0000-1079395200000@exchange.ni.com...
We have just purchased a BioPac MP1 50 physiological recording system
(www.biopac.com). We would like to start/stop an acquisition from
another computer system and/or to add annotations and markers.
To this end it seems there are two routes to consider. We could
either use the built-in Trigger in/out capability with TTL signal of
(0 and +5V square pulse) or use TCP-IP client-server to control it
remotely (i.e. using VIs such as TCP-IP Listen). In the later case,
I'd use the Beta LabView API libraries that BioPac is about to release
for the MP150, instead of the dedicated AcqKnowledge 3.8.1 software,
which is really good.
Because we need to correlate event during the physiological recording
of our experiment, it would be ideal if the resolution were of ms
accuracy (i.e. latency less than 1ms) and we need to manage up to 16
trigger channels.
I have very little technical background knowledge on this. Thus, in
order to help me evaluate a solution, I would appreciate any comments
and suggestions.
1) I would like to know first if anyone could recommend an easy
solution to generate TTL signal (0 - 5V logical pulse) on both Windows
and LINUX PC?
For instance I read about using the 25-pin parallel port, but I am
curious to learn about other possible alternative such as USB, USB2
with or without adapter but also a very cheap card (a couple $100
max). I am already ruling out serial connection, because I am told it
is very slow and has horrendous latency.
2) What are the latencies in read and writing/issuing TTL signals
com? How does it compare with a dedicated byte stream through TCP-IP,
on a dedicated cable and on a network cable?
3) Are they any VI application that you could share to show how
LabView 7.0 can talk through the respective ports to generate a pulse
forming the trigger information being written or read in?
I look forward to hearing your feedback and suggestions. Many thanks
in advance.
Donat-Pierre LUIGI
