TTL triggering tdms AI Data Acquisition
Currently as a part of my research work, I am trying to acquire data in a .tdms file from an analogue channel triggered synchronously by each rising edge of a TTL signal input by a signal generator to PFI0. So to be clear, I won't be having any reference of time. Data will be sampled each time a rising edge of the TTL signal is input. Therefore the sampling frequency would ultimately be determined by the frequency of the TTL signal I input by the signal generator.
Initially I was trying to begin from some examples available, however no luck so far. I hope you guys can help.
Thanks in Advance,
Carl
(3,004 Views)
Hi BCar,
Here is a link to a tutorial on how to set up triggering with DAQmx:
https://www.ni.com/en/support/documentation/supplemental/21/ni-daqmx-data-acquisition-triggering-tec...
Figure 11 will probably be most helpful, because you'll need to use a while loop for collecting many samples.
Hope this helps!
-Ryan
(2,939 Views)
