TTi CPX400 Driver Install
I'm having some trouble with the drivers to remotely control a TTi CPX400 Dual Power Supply. I downloaded the first two drivers from this and from this link. MAX can find the instrument. I have successfully "Mass Compiled" the library, but it still won't come up on the functions palette. I noticed that there wasn't a LabVIEW Library Project in the folder, but I'm not sure how to go about making one at this point.
(4,517 Views)
Do you know if the drivers are located in the correct folder? Otherwise, they won't show up in LabVIEW. Let us know if you've followed the steps in Installing Third Party Instrument Drivers already.
Mike B.
Technical Support Engineer
(4,483 Views)
