TWAIN scanner interface
Hello LabVIEW wizards ,
has anyone of you tried to retreive scanner-data from within LabVIEW
with a flatbed-scanner using the standard TWAIN DLL's ?
I can't seem to find any examples doing so .
Ultimately I would like to let LabVIEW automatically scan a preselected
part of an A4 page without any user-interface .
Any help is appreciated ,
René Ramekers
Océ-Technologies B.V.
The Netherlands
Message 1 of 9
(8,344 Views)
You will be able to automate most of the process but (I believe 95% sure)
most scanner models
present you with a configuration window that you must interact with each
time
a scan is performed. You can open this window with TWAIN but it asks for
user input. I could be wrong here but I believe your problem won't be with
TWAIN but
with interfacing with proprietary scanner software to allow automated scanning.
Message 2 of 9
(8,344 Views)
Go to www.graftek.com
René Ramekers ñîîáùèë â íîâîñòÿõ
ñëåäóþùåå:38E89F05.6FA92374@oce.nl...
> René Ramekers
> The Netherlands
Message 3 of 9
(8,344 Views)
why should anyone have to pay for $595 for a  Twain driver for Labview?
Labview should supply one if enough customers request one.  Is there some kind of illegal agreement between Graftex and NI?
If I have to develop my own Twain driver, I will release it FREE to anyone who uses Labview.
Message 4 of 9
(7,707 Views)
If you think the 595 $ is to much for such a driver you should simply try to write your own. You will find out that this is a very taunting task since Twain is a very complicated API to access and even more complicated to integrate into LabVIEW in a way that it works well.
And NI could of course create their own and sell it as a Toolkit but what would you gain with that? NI Tookits usually start at a higher price point than this Smiley Very Happy
Rolf Kalbermatter  My Blog
Message 5 of 9
(7,263 Views)
Do you have some experience with the gragtek Twain driver at CIT Netherlands?
Message 6 of 9
(7,168 Views)
I downloaded their evaluation version once and played with it. But we use our own library for applications.I developed it mostly for the fun factor and to proof that I could do it, but if I would have had to account for the time to develop it (did alot of it in my private time) it would have been a very costly exercise Smiley Wink
Unfortunately I can't post this library for free and we do not intend to sell it as support would be a nightmare.
Message 7 of 9
(7,164 Views)
I've used Alliance Vision TWAIN driver for an application. It seemed ok for a few scanners I'd tested (via WIA driver).
Message 8 of 9
(6,933 Views)
Long time ago I have done very simple wrapper (based on free EZTwain Classic interface).
You can download this exercise from this topic: non-Dcam camera - get image with irfanview?
(also included in my "vision toolkit". After install just open VI from <LabVIEW 2009>\examples\ADVision\Twain Examples\)
Its free.
Hope it helps,
Andrey.
Message 9 of 9
(6,914 Views)
