Tab Caption page color
How can i change the color of the caption for each page on the tab control??
(3,123 Views)
Not sure if that's possible.
However, you can give each page a different color.
To enable this, create property node>>select property 'Allow Multiple Colors' >>change it to write and pass a "TRUE' boolean constant to it.
Hope this helps
(3,113 Views)
that i can do.
But isn't that i want to do.
I just want to change (programatticaly) the color of the text in one tab.
(3,111 Views)
You can do that by creating a reference on your control/indicator and by using a property node with two properties. The first one select a current location (column/row) and the second one select a color (for background for instance). to change text color, use the same method.
Does this fit your needs?
regards,
BRAUD Jean-Philippe
Field Sales Engineer - Nord et Centre France
LabVIEW Certified Developper
(3,096 Views)
I don't think you can change the color of the text for individual pages, so you might need to hide the tabs and create a cluster of buttons to control your tabbing. Then, you can change the text on each button.
___________________
Try to take over the world!
(3,091 Views)
