Tab Control Question
Dear Sir
If I have a control in the front panel of one page in tab control and I want to add the same control in another page in tab control to use it. How can I do that ??
I'm waiting your reply
Message 1 of 18
(4,706 Views)
Do you want there to be two identical controls or one control visible on both pages?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 2 of 18
(4,698 Views)
Yse I want there to be two identical controls so when I change one control in one page, the second control changes with the same values in the second page
Message 3 of 18
(4,694 Views)
Then you are probably going to want a loop with an event structure.
One event would be: Changed Value on control 1.  When that happens, you need to also change the value of control 2 (to the same number).
Second event would be: Changed Value on control 2.  When that happens, change control 1 also.
There are  a variety of ways of changing the value of a control (the easiest, but least elegant is to use a local variable) -- the important thing is the event structure.
-Matt Bradley
Message 4 of 18
(4,690 Views)
If you want a control to appear on ALL pages of the tab control, move it in front of the tab control rather than placing it in the control.  To do this, place the control on the panel outside the tab control and select it.  Then move it over the tab control by using the arrow keys.  The control will be visible regardless of the tab page selected.  If you drag the control or click and drop it on the tab, it will only be on the one page which was showing when the control was placed.
If you have five tab pages and only want the control to appear on two or three of them, then you need multiple controls.
Lynn
Message 5 of 18
(4,687 Views)
Dear Sir
Thanks for replying, but I can't do it, could you attach an example it will help me more
Message 6 of 18
(4,678 Views)
Lynn
Instead of multiple controls, you could also make the control invisible when a tab is selected where you don't need it.
Message 7 of 18
(4,677 Views)
Could you please attach an example to help me more?
Message 8 of 18
(4,655 Views)
What version of LabVIEW are you using?
-Matt Bradley
Message 9 of 18
(4,647 Views)
labview 8.6
Message 10 of 18
(4,642 Views)
