Tab Control - change page name and color
a)
Is there any possibility to
change the names of pages in a Tab Control programmatically?
(I want to change the names in a runtime version depending on the user
selected language. Therefore I can't use the Import Strings function.)
b)
Is it possible to change the colors of a Tab Control ?
Robert
(using LV6.02 on WinNT)
(8,375 Views)
Michel,
This is what I know (or think I know) about Tab Controls in regards to your Q (I'm open, of course, to any correcting info)...
Because Tab Control names are of enum type, they are read only - so you can't rename them programmatically.
As for colors, you can only change the Label text & background colors, but not the tab controls.
Doug
(8,374 Views)
If you use the property "Independant Label" of the tab, you can change the TabCaption.
You cannot use blank names.
See attached file. It was written with LabVIEW 6.1 and converted back to 6.0.
(8,375 Views)
