Tab Control reference doesn't have same options depending on how I aquire it?
I'm trying to build a VI I can drop in existing VI's with tab controls and programmatically resize the window and tab.  The issue is if I get a reference to the tab this way:
There are no options to set the Pane Dimension
If use right click on the tab I can find it in the list of properties.  I tried to cast it to a more specific class, but "Tab Control" seems to be the only control type not listed?
(2,220 Views)
NVM, found it.
Generic>GObject>Control>PageSelector>TabControl
(2,212 Views)
