Tab Control
Hi everybody,
I am using a tab control and I would like to make a round led (located on the tab control) be visible from every page. Is there any possible way to to do it (except of course from remove it outside the tab).
Thanks in advanced
(4,093 Views)
Hi Thor,
move the LED outside of the tab. Then move it on top of the tab by selecting it and moving by cursor keys (!). This way it will not be part of the tab, but hover above it (you can change the order of elements with one of the buttons in the menu too...).
(4,087 Views)
See the attached example. The led has a black color that disappear when you run the vi. And I'd grouped the tab with the led.
Software developer
www.mcm-electronics.com
PORTUGAL
(4,084 Views)
GerdW and Jorge thank you very much for the help, I appreciate it. I have also two procedural questions for you.
1) How can I rate an answer?
2) By selecting "reply to...one person" is considered that I reply to all the persons that answered my question?
For example now that I have choosen "reply to Jorge" is like I had answered only to Jorge or Gerd W will also see my answer?
Please advice
Best Regards
(4,049 Views)
Hi thorfano,
you can rate an answer if you have a minimum of 50 posts. Everyone in the forum can see your answer.
Mike
(4,047 Views)
Thanks Mike.
Best Regards
(4,038 Views)
