Tab Strip Page
Greetings,
Does anybody know how to add the Tab Strip Control into a LabView
program? By using Active X container, I was able to put one on the
front panel, but I wasn't able to add any types of control onto the
Tabbed page. Why is it that you can use it in VB, or ComponentWork for
that matter, but not LabView?
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(4,000 Views)
A tab control is a separate child-window. It will work well with
controls that each exist in their own window. LV controls are
windowless and therefore aren't compatible with the tab control.
Its also a matter of design. The LV controls were designed to
work inside of clusters, arrays, as constants and front panel
controls, but not tabs, not yet anyhow.
There is a NIWeek presentation from 98 that discusses how to build
a tab dialog using Booleans a
nd a little logic. There are also
some third party tools, like the one from Cardiac, that make it
pretty easy to do tabbed dialogs that look really nice.
Greg McKaskle
(4,000 Views)
