Tab control and Ring???
have a tab control, where results will be displayed on tabs A,B,C
in my vi. i have a ring; of options 1,2,3 when i change them i get various results. (A-C correspond to 1-3)
is there a way when i select '2' on my ring, it will bring up tab B??
hope this makes some sort of sense.
Thanks in advance.
(3,845 Views)
The pages of a tab control are inherently an Enum.
If you create an Enum control, and wire that to a local variable of the tab control, then the Enum control will change to that page within the tab control.
(3,838 Views)
same question, same tab. only i have an indicator in my vi. that displays 16 or 18. i want to create a local variable of this indicator that links to the tab.
when 16 is displayed i want tab A to open & when 32 tab B displays.
trying it here but to no avail.
(3,762 Views)
Case structure driven by the value going to the indicator.
Put Page 1>>tab control into a case for "16"
Put Page 2>>tab control into a case for "32"  (or "18" your message is unclear on this point because you say the indicator dsplays 16 or 18, then you talk about 32)
Put nothing inside  a default case beasue what if it isn't 16 or 32.
(3,756 Views)
This question looks like it is related to your other post. Maybe it would be helpful if you shared exactly what it is you are trying to do.
Mike.
Certified LabVIEW Architect
LabVIEW Champion
(3,731 Views)
