Tab control page Setting problem?
Why I am not able to change the page Label name programmatically. Why the page Label Name property is only readable?
(3,327 Views)
Labels should not be changed. Specify a Caption instead. The appearance is
the same.
Wiebe.
"sashionline" wrote in message
news:506500000008000000FAA50000-1042324653000@exchange.ni.com...
(3,327 Views)
Hello.
If using Labview 7, you must be able to change tab labels programmatically. There is an example called "tab control properties.vi" that shows how to do that.
If using Labview 6 , this link has an example, too.
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3EA9556A4E034080020E74861&p_node=DZ52041&p_submitted=N&p_rank=&p_answer=&p_source=External
Hope it helps you.
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,327 Views)
Well, this is only true for a part... The page caption can be changed.
However, it doesn't seem to be possible to show it!
Wiebe.
"Wiebe@CARYA" wrote in message
news:3f817fcc@newsgroups....
> Hi,
> the same.
> Regards,
> Wiebe.
(3,327 Views)
