Tab control problem
Hello... I have a problem with the tab control function. I can't control both of my scales at the same time. When i press "run", if i start to control scale 2, the buttons of scale 1 doesn't work and vice versa. My VI is uploadet
Best regards
Oesen
(2,534 Views)
Accepted by topic author Oesen
What did you expect to happen?  You have a case structure as the outermost structure on your BD with the tab as the selector!  You only read the tab once and execute only 1 case dependant on which tab is selected when you press run.
Try initializing both VISA sessions and chose which one to communicate with basedSmiley Wink on the val change event of the tab
(2,528 Views)
