Tab control property node
I have a table of parameters I want to display the parameters of the table to the outputs
(4,007 Views)
Okay.   You have the start of a VI with a front panel of controls and indicators.
Do you have a question?
Your subject line "Tab control property node" doesn't seem to have anything to do with the VI you posted.  It doesn't even have a tab control in it!
(3,968 Views)
My question is how to inject the parameters in the vi to the table
(3,966 Views)
You don't have a table.
You have a set of controls and indicators.
You can write data to the terminal of indicators.  You can write data to controls by using local variables of those controls.
I would recommend you learn more about LabVIEW from here. How to Learn LV
(3,961 Views)
