Tab control tabs and pages don't match
The executable bug demo...
Message 11 of 20
(1,328 Views)
HI kc,
You did not reply to my query re: STRICT vs non-strict type def.
I noticed your mehtods enums are saved as strict. Strict is useful when you want to to have a consitant look for GUI puposes (which is why I could understand using it for the tab control) but not for methods (actions).
I am curious if this bug is due to the strict type-def.
Just trying to help,
Ben
Message 12 of 20
(1,322 Views)
Ben-- Thank you for the friendly reminder. I meant to respond and got side-tracked. I am too novice to know the subtleties of whether a strict type def should or should not be used for methods. I have been doing it that way ever since I first started writing with AEs but did so because I found out that using Controls did not preserve instances across VIs. I actually tried this with both a strict type def and a plain type def and obtained the same result. Thanks.
Message 13 of 20
(1,317 Views)
In the absence of any suggestions to fix this issue and the recognition by at least one other user that it is a bug, I am going to assume that NI needs to fix it and that there is presently no work-around.
Message 14 of 20
(1,286 Views)
kc64,
I see that when I open the tab_demo.vi that tab 3 is selected and page 1 is displayed, however, by changing any one of the tabs and then setting that value as default, I cannot seem to reproduce what you originally posted.  What steps did you take to see this behavior?
ColeR
Field Engineer
Message 15 of 20
(1,264 Views)
Cole,
Are you using LV 8.6?
Try an earlier version to see the problem.
Ben
Message 16 of 20
(1,259 Views)
I opened and saw everything with 8.5.1.  Again, I can see exactly what the problem is, I just cannot recreate it myself after setting default values and without being able to come up with any steps to recreate it, it's hard to know what to fix. 😉
ColeR
Field Engineer
Message 17 of 20
(1,253 Views)
I believe the issue is realted to the tab being defined as a "STRICT type def".
Ben
Message 18 of 20
(1,250 Views)
Thanks for pointing that out Ben.  I have duplicated the issue and will be filing a CAR.  I have made new projects for both 8.5.1 and 8.6.1 and verified the behavior for both versions.  kc64, the best work around I can offer at this point is to make sure you save your VI with the defaulted tab active.
ColeR
Field Engineer
Message 19 of 20
(1,238 Views)
Thank you all for your help. I will try your suggestion. Also, thank you for filing a CAR on this issue.
Message 20 of 20
(1,236 Views)
