Tab controls
I have a program with 3 tabs using tab control. The first tab is a login
screen (because this will be used for remote fron panel use), the next is a
configuration tab and the last is the execution.
The login tab is an event structure waiting for a value changed on the
"login" bool button.
The config tab is a while loop that updates different settings which are
later being read from the execution tab and is also used for running small
test executions from within the config tab.
The execution tab is a while loop that reads settings from the config tab
controls and actually manipulates I/O ports.
So far so good. Now, when the VI is started, I switch to the login tab and
disable the others by use of a property node and references. Works well.
Once the user is l
ogged in, I disable the login tab and enable the others
and jump to the last tab. Works OK as well.
Problem: If I start the VI when any other tab than the login tab is in
"focus", that tab will continue running and you can never log in because the
login tab will never get "its turn" even though it will actually disable the
other tabs and put the login tab in focus. Also, I would like for the tabs
to stop running when I switch to another tab and continue when I switch back
to them, thereby only having one while loop running at a time.
Right now, if I stop the while loop in one of the tabs the whole program
stops.
Can anyone help me in the right direction?
TIA,
- Soren
(2,877 Views)
I never thought of the tab control as an actual control, but more of a
display device. Anyway, you can make a local variable from the tab and
write a constant to it to switch between tabs.
"Soren Maigaard" wrote in message
news:ap284d$c22$1@news.net.uni-c.dk...
a
nfig tab.
> Once the user is logged in, I disable the login tab and enable the others
the
the
back
> stops.
> TI
A,
> - Soren
(2,877 Views)
