Tab page "Tabbing Order" property
Years ago I was programming Labview as a regular part of my job and I wrote a program to save values from a tab control recursively so that it would save the individual control values from tabs within tabs within tabs. To do this I used a page property "Tabbing Order" to index through the controls (see attached picture). I want to do that again but this property never appears in the page property menu. It's driving me crazy trying to access the property and I can't find any documentation on how to access it. I'm hoping that someone has the answer.
Thanks ahead of time.
(1,035 Views)
Hello, Xanthan.  Welcome to the Forums.
     Years ago, when I first was learning LabVIEW, I encountered Tab Controls, but didn't like them (and had a difficult time helping my colleagues who had Tab Controls with 15 tabs untangle their Block Diagrams!).
     So when I found something in LabVIEW that I hadn't used recently, but wanted to figure out, I did what I find very effective for myself and my "mentees" -- I opened a new VI, dropped down a Tab Control (with three tabs, named by LabVIEW "Page 1", "Page 2", and "Page 3"), then wrote a little VI that I hoped would iterate through the pages for me (not exactly what you asked, perhaps, but potentially could be used to "solve your problem".
     Found two possible methods -- a "direct iteration" and an array of References to the three pages that could also be used.  See if this gets you started.
Bob Schor
(1,007 Views)
Accepted by topic author XanthanGum
Up to LV2021, you had property "Controls on Page[]", which gives the list of controls in tabbing order already:
Starting from LV2022, the property was renamed "Tabbing Order":
I guess the property was renamed to clearly differentiate from the "Z-Order:Controls[]" property that was newly added in LV2022.
Also, properties "Objects on Page[]" and "Decorations on Page[]" were replaced respectively by "Z-Order:All Objects[]" and "Z-Order:Decorations[]".
Raphaël.
(1,004 Views)
Oops -- I think I answered the "wrong question" ...
BS
(952 Views)
Problem solved, thank you - the project I'm currently working on is in LV20 and I was looking at the old project in LV23.
(931 Views)
Hi Xanthan,
I am glad that helped, don't forget to "Accept as Solution" the comment that solved your issue:
Also, Kudos are the primary way of saying "thanks" on the forum, the secondary being saying "thanks" literally.
Raphaël.
(901 Views)
